Jun 26, 2015
22
Wolverhampton
General Plumber
Hello
I'm new to the forum and to the plumbing world but I start my course in September and in the meantime I though it would be a good idea to start accumulating the tools of the trade for the future as I'm sure they won't be cheap, so really I just want to know where do you recommend I do my collecting and what are the good brands to look for, when I was a mechanic it was all about snap-on so which brand is the one for plumbing.
Thanks guys
If your working with someone, using there tools as you start off then buy what you, use most
But basic tools you'll need is
Tool bag/box
Screwdrivers
Stanley knife
Good tape measure
Pencil/sharpie/pencil sharper
Hammer (don't buy cheap, most people I've worked with have owned there hammers for 20+ years)
Adjustable spanner
Pipe slices
Plastic pipe cutters
Pipe débuted
Pump pliers
Hacksaw junior+normal
Boat level
Tool bag/box
Screwdrivers
Stanley knife
Good tape measure
Adjustable spanner
Pipe slices
Pipe débuted
Pump pliers
Boat level
Pipe débuted never heard of one of them ? 😀
This Wet and dry Vac......I use it all the time and it's brilliant!
[DLMURL="http://www.wickes.co.uk/Wickes-Wet+Dry-Vacuum-With-Blower/p/215735"]Wickes Wet & Dry Vacuum With Blower | Wickes.co.uk[/DLMURL]
Reactions: 2 people
If you go to car boot sales and see a 30+ year old shifter that still works - buy it.
I bought a 24" bahco shifter 15 years ago, and still have it.
I don't know what it did before I got it, but if it had a harder life than I have given it - it has stood the test of time
The bloody thing is probably older than me - but I'm going to take it to the grave with me.
one of the best tools i got when i started off last year was a split ring compression fitting spanner (recommended on this forum actually)
you wont get a leak on 15/22 mm compression fittings when using that bad boy. touch wood :dizzy2:
I'm currently doing my level three, but I've got a 4" bahco adjustable, a 6" todays tools wide jaw from tool station and a fat max neon flat head. These are the tools that are always in my elephant ears and i think extremely good value. Apart from that I'd recommend a decent pair of knee pads and bahcos small socket set
hi,
as a newbie in plumbing you can purchase used tools for cheap rate. And whenever you get experience and proper skills, you can upgrade your tools. According to me, i had purchased used tools from plumbing professionals near my town. I think sites like https://www.nriparts.com sells used tools for cheap rates. If you can afford the cost, then you can purchase new tools.
(uk) :d
Best of the lot
Reactions: 3 people
what do you use your impact driver for mostly ?
anything and everything, hanging rads, boilers, rad tails- got a trv tail driver bit for it(real time saver), noggins, clips, pretty much anything that involves a screw. I work on new builds mostly but i know they can be a bit loud when working in occupied premises especially if its late.
Reactions: 2 people
thought that's what you were talking about. My boss doesn't let me use impact drivers for anything as he says they are too rough
Depends how you use them. On ordinary pozidrive screw heads they can be rough, but so can a combi drill. Use the correct and unworn bit for a start. Also you can get an impact driver that has 3 different speed/torque settings & can be as gentle as a normal cordless drill.
Excellent for driving in thunderbolts or coach screws.
Impact drivers are so compact and lightweight.
