Tool not invented (I don't think)
View the thread, titled "Tool not invented (I don't think)" which is posted in Plumbing Tools on UK Plumbers Forums.
And the rothenberger 2in waste pipe slice cuts the inner plastic flue perfectly with no bits to file/cut off
Still not as good mine though--Triangular silicone tube nozzle brill eh.Obviously only triangular on cut off section would give a perfect finish around baths worktops etc.
One of you young bucks go and market this..brum
I mark mine with a old skool damp course rap and a sharpy
cut with 18volt angle grinder and 1mm slitting disk
and clean up with a flap wheel
And add chamfer flue inside
lube up and slip togather
TA darrr
As per Ermi, but I'd make up a 45 degree wooden V block to sit the flue in with a slot cut crossways so as you're not cutting into the wooden v block everytime you use it
Reply to the thread, titled "Tool not invented (I don't think)" which is posted in Plumbing Tools on Plumbers Forums.
southcoastboile,
wetdrip,
