View the thread, titled "Traymate Shower tray" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Hi guys,
This is my first post so apologies if this isn't the right section for the post.
I'm a qualified plumbing and heating engineer with nearly 20 years experience under my belt.
I have an issue with a (client supplied) TM Traymate shower tray/trap and wondered if anyone else has had similar issues? As you can see from the pictures, it has cracked directly inline with one of the two fixing screws which retain the entire trap. The shower tray has been installed for around 6 months and has been leak free up until the clients child stubbed her toe on the decorative cover which covers the waste.
Traymate instantly put the issue down to 'installation fault, over tightening of the two screws' and have washed their hands of it. Their manufactures instructions do not specify how tight the two screws need to be and simply state 'do not over tighten' and when I questioned this to their technical team they could not give me an answer either. In addition to that, the tech team also said that in the event of over tightening the grey retaining ring splits, however as you can see from the pictures it is still flat and intact.
In my professional opinion, relying on two 25mm wood screws to hold a trap onto a 3mm resin rim in just two places is destined for only one thing.
Strangely, despite their claims of having a lifetime guarantee they have dismissed any issue with being an installation fault without a site visit or even looking at the pictures and given the rather abrupt and automated response from their tech person I feel as though they get this issue more than they are letting on.
Id be interested to know if anyone else has had similar issues or would like to comment on if they also see the trap design being up to scratch.
Many thanks
Yep trap looks the same as what’s supplied with a Mira flight tray
So if you need spares phone Mira up and ask for a new trap the ring should fit
I’ve cracked one on install wasn’t even tight just cracked on the same place as yours put it down to not much meat on the plastic / bubble in manufacturing phoned Mira up sent a new one out under warranty
Thanks for the reply - the trap is fine (I think the first picture I uploaded isn't particularly clear) its the tray that's cracked. Mira have always been pretty decent, Ive fitted about 20 Mira Flights and never had an issue.
Surely the client standing on the waste outlet would exert a force onto the edge of the tray and be as likely to crack it as an over-tight screw? My feeling is an overtightened screw would/should strip out the thread, not crack the tray.
Not speaking from specific experience with this design, but my feeling is you genuinely haven't done anything wrong. Traditional wastes clamp the tray/bath, sink between the two halves of the waste and do not exert an uneven force that is likely to result in this kind of failure, but it seems the tray itself is weak and unfit for purpose if it breaks this easily.
Hi, I appreciate that this thread is now quite old but we have just had exactly the same issue with the same waste etc and are in the process of complaining and requesting a replacement shower tray with associated costs. I wondered what your outcome was and how they dealt with the complaint assuming your basis was substandard product and NOT installer fault as we are?? Thank you (householder, no plumbing experience at all)
Reply to the thread, titled "Traymate Shower tray" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
Thread starter
Joined
Heating Engineer (Has GSR)
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
shower
Jeefa,
Tanya A,
