View the thread, titled "Tricky washing machine waste problem" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi, first time on this forum but I could use some washing machine waste advice.
My brother and I are redecorating our entire house, including the rather small kitchen. We'd like to move the washing machine which is currently in the kitchen to make room for a dishwasher.
An ideal location for it would be at the top of the cellar stairs along with the tumble dryer. Running the hot and cold water lines shouldn't be a problem but the only waste drain location is outside the kitchen (the reason for the washing machine's current position) and the dining room is between the cellar stairs and the kitchen. The dining room has a concrete subfloor so running a pipe though this doesn't seem doable, especially with the right drop. The only option left that I can see is to run the waste pipe through the dining room ceiling but this presents the problem of gravity.
I've attached some pictures to help with understanding how things are laid out (excuse the mess but we're in the middle of redecorating). Open to any suggestions, however radical, although the cheaper the better.
Yes and No, plug the front inlet and keep wash cycle down to 30 degrees and it will do it as long as you understand you will macerating water. 😎
Balance the cheapness of it against the cost of replacing it and clearing up the mess when it stops working and/or leaks- it's cheaper for a reason.
£90 for a macerator why would you, that's got problems written all over it.
If you want cheap, black bucket and cheap submersible pump. Oh and a big mop.
Reply to the thread, titled "Tricky washing machine waste problem" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Business Name
Mr
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
alexjhill,
SimonG,
