diamondgas
Hi folks ... I'm hoping the quality of the image above is reasonable?
I've circled the part and numbered 1 and hope someone on here can help me out. I have had very little to do with underfloor heating systems but understand the principle of how it works. When I got to this job the circulating temp (3) was 30degC. The thermostat (1) wouldn't make a difference. I removed the head, still no change in the circ temp. A few taps of the spanner and pulling on the spindle seemed to free it. You could hear the water move through the valve and sure enough the temp started to rise. Unfortunately the thermostat did nothing when i replaced the head. The flow circ temp rose to 60degC!!! No mater how I tried to adjust the stat, nothing happened! So the only 'control' I had to adjust the thing was to close off the flow manually until the temp started to drop!
The valve is 3/4" and the mark on it is 'VAO' ... Anybody recognise this and can point me in the direction of a replacement then I'd be grateful 🙂 The manifolds are 1" and the centres are 210mm (2) I know you can get a replacement pump set but I'd rather not go down that line if there's a replacement out there for the flow regulating stat.
Over to you all 🙂 Anyone able to help me out?
Thanks for your assistance....
Steve
