sa321
Doing a new installation and wondering if I can position manifold below the UFH loops level?
how would I get rid of the air if it gets in the loops. will it be caught by automatic airvents?
You would need to get the main on it to push the air out. Its a pain in the neck if you need to drain down and refill the system. Expect a call back if you fit the manifold below the circuit.
Not a problem with siting it below the loops, very common on houses with First Floor UFH. Just purge each loop as normal, isolate & do the next one etc. I've never had a problem & done loads of houses with FF UFH.:yesnod:
