Guest viewing limit reached
Underground Clay pipe.
View the thread, titled "Underground Clay pipe." which is posted in Renewables on UK Plumbers Forums.
The soil stack in my house has been leaking underground and I have found that it is coming from the clay bend that goes off to the sewer as the bend is broken/cracked. I need to replace the bend and was wondering the best method of doing this.
I understand that I will need to cut the clay pipework. Will I need to do this on a straight piece of the clay pipework and then replace the bend with a plastic bend. If so what is the best fitting for connecting onto the clay pipe (underground) and do I need to use any sealant or cement/mortar with the fitting.
Many thanks
Daz
this should be covered on building insurance, do your self a favour and get someone who knows what they are doing in, if you mess up on salt glazed pipe you could be chasing breaks forever.
Instead of digging a big hole in your hose get it relined from outside had one done in summer for customer cost £300 quid but guranted and less invasive to customers house
Reply to the thread, titled "Underground Clay pipe." which is posted in Renewables on Plumbers Forums.
dazetti,
johnnyplumb,
