Nov 14, 2021
201
14
18
Dorset
Press Release Submitter
I had an unvented cylinder (and gas boiler) installed by a Gas Safe Register engineer. He later informed Gas Safe Register which issued me a gas certificate. But Gas Safe Register told me I should have a Building Regulation Certificate for unvented cylinder installation.
But the gas engineer did not arrange that unvented cylinder certificate for me.
I checked he has no G3 qualification.
Is this the reason he did not arrange that unvented cylinder certificate (via Gas Safe Register ) for me?
What would happen or what consequence will be if he is not G3 qualification?
Looks fine only nit pick is combo / inlet valve not above cylinder but that’s only a real issue when servicing cylinder just needs to be drained
Hi Shaun, did you mean draining will be the cylinder itself, not the primary water of your heating system?
Actually, when someone comes to do annual service for boiler and cylinder, do they need to drain the system every year/time?
Thanks in advance for letting me know!
Reactions: Ric2013
Around half of your hot water from the cylinder (not water to your radiators) would need to be drained should there be an issue with the brass combination valve.
It’s not fitted wrongly as there are no rules about where it should be fitted but best practice is to fit it as high as possible.
  • Informative
Reactions: Ric2013
Thank you Scott_d for your input!
According to what you said, if no issue with the brass combination valve, then no need to drain the cylinder?
That is to say when do servicing cylinder no need to drain it?
There isn't a need to drain on servicing as you can take the filter out without draining it as there's a non return valve after the filter. Providing it isn't faulty you should be able to clean the filter out.
As others have said it's best practice to fit it high as possible, but it isn't incorrect. I've fitted many low down due to installation constraints etc. Even the one in my own house is nearly at the bottom of the cylinder.
Thanks a lot for this point!
I thought every time do serving needed to drain the cylinder due to low positioned combined valves...
If no need, then it is simpler for both engineer and my mind🙂
By the way, cleaning the filter out is part of serving right?
Thank you Simon!
indemnity policy seems a good idea as I heard building regs notification/Building Control cost is hundreds of pounds...
I attached photos for your reference, if you need more detailed photos or different angles please let me know!
I understand your general note, but I assume many normal customers/household people won't know what qualifications to do the gas jobs. I knew he was worcester bosch accredited installer, I knew he is GSR registered, I thought that was enough.
But only GSR today confirmed to me I do need unvented cylinder installation certification which only can be issued by G3 qualified engineer....
Nice if blockLooks like it's fitted correctly, and overall not a bad job. I've seen qualified G3 engineers do much worse of job, and leave them in dangerous conditions...
I'd leave it, it's fitted now. You'll struggle to get anyone else to sign it off, and the cost of getting it authorised by Building control will just be not worth it.
Old thread now..But... Nice if group-block was higher up and from the tiny photo on my phone I assume the T&P has its own tundish or connects to one that is showing as cannot see clearly.
Ignore my last comment. I can see it is a Tee not an elbow now on the PC big screen
V
UK Plumbers Forums
Deleted member 120897
