Unvented cylinder size
View the thread, titled "Unvented cylinder size" which is posted in UK Plumbers Forums on UK Plumbers Forums.
200/210 or 250l indirect unvented cylinder...
Pros and cons of both please guys, whats the thinking??
Better to go bigger, or are there other considerations to be thought of....?
Lost how mate? A new boiler and unvented cylinder with the boiler wired to a external weather sensor , I've recommended a water softener above . Kop
SO, at present im on a y plan, am i right in thinking, with an unvented a cylinder, it would be best to change over to an s plan, with the two valves close to the boiler? And if so, do i require an extra 5 or 6 core wire to link up new valves,??
If the y plan stays, i assume the new valve just goes near the cylinder somewhere and gets wired to the control centre....
Just want to try and do half a job! But do it right once!
New boiler is a bit costly at present...
Weather compensation, if that's what you are still considering (I've lost track), is incompatible with standard S-plan with a cylinder as one zone because most of the time the CH water is below the 65°C minimum needed to heat the cylinder.
Various ways to do it but here's the Ideal wiring diagram for their heat only boiler and unvented cylinder with a outdoor sensor installed .Kop
5 core and basically yes I'd change the 3 port to two or even 3 - 2 ports zone valves does your property need to be as warm upstairs as it does downstairs?
Bungalow....
Big bungalow? Still applies bedrooms and living areas can be split up all these little things add up to more control over your heating and savings on energy, the one big thing to remember is insulation 350 mm in your loft space is now the norm walls , floors I'd do the lot if I could in reality you probably can't 🙂 but just do what you can.
4 bed, yeah, i suppose its big by todays standards, 80s...so insultaion is poor at least...on a hill to, so we catch the easterly blows!
As KoP suggested the best thing you can do to improve efficiency and comfort is to improve insulation - it really can't be overstated!
Weather comp is underrated too I think and is definitely possible with s-plan type setup. You could search for X-plan as an option, it does start to get a bit technical but well worth a try.
I just re-read this. I first read it as no more than 7 minutes at a time. Apologies, how long are you in there? 7 minutes is a long shower in my book. If it's going to be over 10-12 min each one after another, go bigger.
No idea! Ive never timed it tbh!!
I have more on my plate than thinking about shower times at present....selfish but true....shower time is my escape, my down time
Is that INC VAT and you supplying all the materials and sourcing them? Or they sorting materials too.
Thats purely the labour content.inc vat. I have the cylinder, they say to supply pipe and fittings. Plus 1 zone valve.
Change y to s plan.
Move mag filter, as apparently its only on heating return and doing nowt for the boiler.
Raise f+e tank in loft.
Fit cylinder in loft on platform ive built.
Pipework to be run up new airing cupboard wall. Its a blank canvas in my book...
Am i so out of touch with life in 23!!?
I would as your having the cylinder in the loft better heat up times customers report and not open to atmosphere so better water quality if flushed
Reply to the thread, titled "Unvented cylinder size" which is posted in UK Plumbers Forums on Plumbers Forums.
Notagainpike,
Notagainpike,
