Unvented cylinder size
View the thread, titled "Unvented cylinder size" which is posted in UK Plumbers Forums on UK Plumbers Forums.
200/210 or 250l indirect unvented cylinder...
Pros and cons of both please guys, whats the thinking??
Better to go bigger, or are there other considerations to be thought of....?
To have a high resistance so when hot water only is on it doesn’t pump over
You are assuming the feed and vent are connected either side of the boiler? I'd have the feed and vent both on the suction side of the pump on a low head system, no pumping over and only consideration is enough head to prevent cavitation.
Like this. Both cold feed and vent on the flow pipe off the boiler.
Reply to the thread, titled "Unvented cylinder size" which is posted in UK Plumbers Forums on Plumbers Forums.
Notagainpike,
Notagainpike,
