Upgrading hand tools
View the thread, titled "Upgrading hand tools" which is posted in Plumbing Tools on UK Plumbers Forums.
After not doing plumbing for alot of years my tools could probably do with an upgrade eg my bacho 10,12 inches open about as wide as a 6inch wide jaw now.
I see the armeg jaws for taps so probably going pick up them.
Also see knipex adjustable wrench that looked good.
Any tool ideas to make life easier and how you use it im interested in hearing them.
Yep, I’m a big knipex fan myself. The flat jaw one, that’s advertised as a wrench I have, and is very good. I also have the small knipex pump pliers and larger of them use them often. Still own footprints, for just in case. Had expensive and cheap screwdrivers, so pot luck with them.
Had a pr of Knipex 250 bilateral grips (flat/smooth jaws), wife bought them for me birthday couple of years ago, about £50. Left them on the job a few weeks ago never to be seen again 😵. They've recently launched a 300mm pair.
Also got a pr of Knipex Cobra 300mm they're brilliant, larger and smaller available.
If it was me I'd like to only buy Bahco, Knipex, REMS, Rigid, Teng, Wiha, Wera etc however there are other tools out there too.
I was tidying up and old toolbox and found a pair of compression fitting spanners, you now the ones made out of press steel and oversized so you can get them easily on a nut. Trouble is I found they they also easily slip off if not perfectly square, anyone still use those, they might he more use if I spot weld them together and add some thickness?
I don't think you can fault Bahco chrome plated adjustable spanners. They don't rust like others, I've got ones that have survived 5 years in industry.
I'd always buy Knipex grips too, Rothenberger just buy stuff in and stick their badge on it, I've found their quality variable as best.
The Armeg jaws I think you mean are basically a fancy but comprehensive set of basin tap wrenches.
Someone, had me cobras and vicegrips the other day. That's the trouble, everybody else likes 'em too.
Reply to the thread, titled "Upgrading hand tools" which is posted in Plumbing Tools on Plumbers Forums.
Under the sink,
WC1,
