Oct 28, 2017
122
19
18
67
South West
DIY or Homeowner
Hello.
Trying to work out options for my bro's top-floor flat which has truly pants mains pressure and flow. I estimate it (not actually measured, but from my recollection) to be something like 5lpm and well under 1 bar pressure - the kitchen cold is a 'fast trickle' at best, and the CWS takes ages to refill.
Looking at replacing it all with, say, a Stuart-Turner MBF-200 or even a Challis Booster Plus which should transform the situation - on which point, has anyone had any experience of either or of other makes and can make a recommendation?
One concern I have - I'd also like to boost the flow from the cold kitchen tap if possible but can see issues with this. When the pump on these tanks are running - drawing up the mains water at 12lpm - wouldn't opening the kitchen cold tap cause zero water flow from there and even allow air to be sucked in?! I guess a check valve can be fitted, but that wouldn't prevent the flow from stopping altogether.
I will be asking this of S-T and Challis, but I wonder if the kitchen cold supply could be taken from the outlet of their unit's pump so the pump will fire up for both refilling the tank and for the kitchen tap?
Anyone with any experience of these?
Better still, any plumbers here serving W2 London?!
Thanks.
Your best option would be to put the unit where the main stop tap is in his property and boost all outlets only problem is you will require a decent sized unit
let's say you want around 2-3 bar and 20lpm coming out the tap
And let's say the unit is 200l
That will give you 10 minutes maximum (more like 6-7 actual)
So you really require around 5-600l stored for a decent supply
Thanks again Shaun.
Space - but mostly noise - would be an issue with having it inside the flat. And we already have the dedicated 'shed' on the roof, built to hold the existing CWS.
Thanks for you comments on required volume - we will look at that carefully.
Has anyone had any experience in fitting one of these pressurised (by a pump) accumulators?
Since it 'stores' the water, I'm guessing it cannot be considered 'drinking' water, so the direct link from the mains supply to the kitchen tap needs to be maintained. In this case, what happens when the pump is running?! This will surely deprive the kitchen tap and it'll even try to suck air through it?!
It was built to hold the CWS, so has a small amount of access room around it, but not a lot to, say, fit a larger CWS.
A pressurised accumulator would fit easily as they are taller but narrower.
If we can boost the mains so as to refill the existing CWS more quickly, then that would be fine and is another solution we are looking at.
For info, I've had confirmation from Challis (one of the manufacturers of pressurised cold mains storage systems) that the water is potable since it's a sealed system; the cylinder is basically considered to be a 'short large' pipe!
