W
willing2learn
Called to this job last week. Some downstairs rads not getting any heat, but others are and all upstairs hot. Customer has had someone fit a new pump to boiler and power flush system. I took a cold rad off and flushed it out with a hose, quite a bit of sludge came out. I then attached a hose to the flow and return tails from in turn and flushed a lot of water through, this all came out clean.
Put rad back on, still cold. I'd tried shutting all rads down as well and just leaving cold one open, that didn't do it, so not a balancing issue.
he has a magnaclean fitted, cleaned that out, only a small amount of crud in there. I put the boiler in chimney sweep mode and it did seem to 'kettle' a bit, like it was struggling to push the heat round quick enough, and would then cut out, i gave the main heat exchanger a few taps with rubber mallet, this seemed to cure the kettling, but still no heat to cold rads.
are there any filters that could be potentially blocked in boiler? Toying with the idea of power flushing just the boiler to see if that cures it.
any advice greatly received.
