Nov 12, 2020
DIY or Homeowner
Our Vaillant EcoTec Pro 30 makes a loud clicking noise every few mins after the heating comes on. Eventually, after about 10-15mins it stops, but the weird thing is it also happens the same (clicks every 2-3 mins for 15 mins) after the heating is switched off.
Here is an edited clip of the clip happening 3 times. The first click is about 2 mins after the heating is switched on, the second and third clicks are after ~5 and ~8 mins when the boiler is running at full power.
Other than the clicking, everything else with the boiler works fine.
Any ideas?
Sometimes the bolts on the back of the burner need tightening , also needs copper slip on the studs that hold the main burner into the heat exchanger it's a routine job and should be carried out on a service when the G10 seal is replaced it comes in the replacement seal pack contact your service engineer . Regards Kop
  • Informative
Reactions: Aquarius
W
5K
W
