Nov 14, 2022
Currently in Osijek but otherwise Australia
DIY or Homeowner
Vaillant Ecotec Pro MK 1 combined gas heater does not keep temperature when using shower or basin tap. Boiler heats up to 65C, then a few seconds later turns off and temp drops down to 54C. Have tried different temp settings but no joy. Any idea about possible defect/fault? I have short video showing the issue.
Could be the diverter, or as Shaun says a few things. A blocked plate ime usually the temp goes up to 80 degrees plus.
One thing you could try is isolating the cold inlet for the hot water under the boiler, run a hot outlet and see if water carries on running.
