Billy Bob Bob
Ok so how do i adjust level. I will try anything at this stage to get a nights sleep.
you cant you need a gsr engineer
I came across one very noisey Vaillant ecoMax pro 18e (system boiler), it turned out that the pcb had been set up for the pro 28e model (over gassed) but your noise could be something completely different. Did it make the noise when the Vaillant engineer tested it?. By the by, when it come to comparing engineers from different companies or manufactures you can find good & bad ones from most of them (yes even BG), some intermittant faults can test the best of us and diagnosing a fault on an internet forum is not always that easy either.
Martin
Well said!you spend 4 years training, take lots of exams, get gas safe registered, spent upto and over £1000 on an FGA and other associated kit , then you can look at the tech data on your boiler and adjust the gas valve setttings based on your fga readouts in order to set up your boiler correctly. Or you find a goood rgi and have them do the job a lot cheaper and hopefully correctly.😀
Please use a gas safe registered engineer, corgi lost the franchise to isse "licences" to engineers last year and anyone still claiming to be corgi registered may be a cowboy and not hold gas tickets or therefore be insured to work on gas.😱Ok if incorrect Co2 level is the likely cause of "fog horn" type noise each time the Boiler demands heat then I will get a CORGI registered plumber to check and re-set if necessary. As I said this loud noise only lasts 20 seconds or so each time Boiler calls for gas but it's extremely irritating and annoying the neighbours. I realise a forum cannot diagnose problem but I would like to understand most likely cause.
Reply to the thread, titled "Vallaint Boiler "fog horn" noise" which is posted in Boiler Advice Forum on Plumbers Forums.
