Dec 23, 2016
Afternoon all, just try in identify thus valve, circa early 2000's. Bought a replacement from Toolstation to do a quick change. I wanted to keep the nut and olive on the 10mm pipe and replace the leaking body of the valve. The threads were different!!
Afraid to say normal for 10 mm compression fittings hardly 2 manufacturers the same
If you can get nut below olive easiest solution is to carefully use a junior hacksaw and cut old olive off. Cut at 45 degrees when nearly thro use thin bladed screwdriver to snap olive.
