L
LondonerCOOPS
Hi there, I was wondering if someone on the forum could help me:
Our Wall-Hanging Basin in the bathroom needs support since it is gradually coming away from the wall causing it not to drain quickly enough to avoid scum build up.
I have been doing quite a lot of research to try to find a solution, originally in terms of fitting a bracket, but I have still not found a solution.
The basin is made by Laufen and I have been advised that this model is not designed to normally work with a bracket.
The basin measures approximately, 590mm wide, 430mm out from the wall and 670mm off the ground. I have uploaded photos to illustrate the issue.
I understand that the pictures show the basin uses basin bolts with small nylon nuts holding the basin to the wall.
I have been advised to re-hang the basin using longer fisher/fischer bolt fixings‎ or M10 basin bolts but I am unclear if:
a) the problem is the existing bolts giving way or if the problem is the strength of the wall itself (when I tap it, it sounds like a stud wall - hollow sounding but solid in some places); and
b) if new bolt fixings‎ would need to go on to a secure fixing in a stud wall like a concealed frame or hanger system
I would prefer not to have invasive work carried out but also prefer not to have to sit the basin on a piece of furniture or have legs fitted.
Because of this, I thought a suitable bracket might offer a solution and the 'Bracket 400mm - Pair – Professional Products ... - Twyford Bathrooms' product was the best I have come across:
If anyone knows of any products such as a bracket that might do the job, any other ideas for a solution; or any recommendations for a bathroom/plumbing specialist who might have a solution, I would very much appreciate that information.
Even if suitable basin brackets could be found or adapted they would still rely on fixings to a back wall of suspect strength. Fortunately the basin is recessed, so a rail could be fixed, across recess, parallel to front of basin, set back and at a height to give basin support. 15mm chrome rail is readily available as is 12mm threaded bar. Inserting bar in rail would create adequate strength whilst outward appearance would resemble a chrome towel rail. The underside of basin may not be level, but packers siliconed to U/S would allow for difference.
Thanks Joni.
I agree with what you say, and I would not want to go through that situation of having to same problem but with the sink support rather than the sink.
The rail idea sounds like a good possible solution. Are these items you sell or if not, could you please direct me to a product like you are talking about?
Thanks again.
Dear all, thanks for all this input and sorry for the delay and any confusion.
Just had it confirmed that it is a brick wall.
The rail idea sounds like a good possible solution. Are these items you sell or if not, could you please direct me to a product like you are talking about? QUOTE]
15mm chrome plated copper pipe together with 12mm steel threaded bar are readily available at Toolstation or similar outlets.
Are these the kind of thing you mean?
toolstation.com/shop/Plumbing/d20/Copper+Pipe/sd2909/Wednesbury+Chrome+Plated+Copper+Pipe/p49401
toolstation.com/shop/Screws+%26+Fixings/d90/Stainless+Range/sd1030/Stainless+Steel+Threaded+Bar/p37920
How would these 2 items be combined to support the basin?
Did Ray really just put a link up to a rival merchant? haha
