Good morning to you all, 1st post so please bear will me.
I have recently refitted my bathroom, new shower bath, wc, basin, radiator, floor (ply sheets + laminate) and Multipanel on the walls.All good and no problems so far.
I have purchased a theromostatic, composite, ceiling fed, pumped mixer shower made by Mira and it is suitable for my gravity fed system (bathroom and HWC on 1st floor and CWT in the loft). I have followed MI's and have positioned the combined valve/pump unit in the loft and have run a 15mm feed to it from the CWT (both in and out feeds on the unit are 15mm). I intend to run the hot feed from the HWC to the unit by means of a WarwichWarix flange. Problem is that the largest outlets I can find on this type of flange are 22mm. This will not be a problem for the direct feed to the pump/valve unit as it will eventually have to reduce to 15mm. However, if I connect the other 22mm outlet on the flange to the existing pipwork for the hot water supply to the rest of the house will it affect the water pressure at the taps? I know that the 28mm pipework reduces to 22mm at some point and that ground floor hot water taps shouldn'd loose pressure, but, 1st floor bath is already slow to fill.
Thank you
Thank you
