Matt0029
1,245
110
63
37
leeds
Heating Engineer (Has GSR)
Hi can anyone recommend a good waste water pump. For clean water so won't need a macerator bit. It's for a waste run that now has 6 meters pipe with a fall of 20mm. So well out of limits for the required fall. Has been tested yet but I don't think will work without a pump.
It would need a trap on the straight run of waste pipe. Wondered whether they would be enough pressure to force from a hepvo trap horizontally with the lack of fall.
With hepVo traps you loss about 10/20 between inlet and outlet.
There's the mcalpine one that is straight so wouldn't loss any fall on the trap like the hepvo. But sure I read somewhere these aren't to be used on showers. So may not have the force in the water to open it? Thanks
May try the mcalpine one. I could use a running trap but I think the machine is only emptyied every week or 2. So not sure if evaporation will be a problem.
