Wc pans Positioned back to back
View the thread, titled "Wc pans Positioned back to back" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi I’m doing up a cottage. By rearranging a couple of walls upstairs I can replan the bathroom (making it smaller) and include an en-suite to one of the bedrooms. But to achieve this means that In plan the wc pans will be essentially back to back with a wall between. I can position one of the wcs so that its spaced 2-300mm off the dividing wall. is it possible for the wastes from the wcs to use the same waste pipe via a double branch of some sort or do the wastes have to be offset in some way? Thanks
Avoid a double branch I have had to change this configuration on a job as when the cistern is flushed it will fill the pan you will need to offset the connections have a look the attachment, page 18 shows how to do so it works.
Reply to the thread, titled "Wc pans Positioned back to back" which is posted in UK Plumbers Forums on Plumbers Forums.
Dobedo,
king of pipes,
