Wc pans Positioned back to back
View the thread, titled "Wc pans Positioned back to back" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi I’m doing up a cottage. By rearranging a couple of walls upstairs I can replan the bathroom (making it smaller) and include an en-suite to one of the bedrooms. But to achieve this means that In plan the wc pans will be essentially back to back with a wall between. I can position one of the wcs so that its spaced 2-300mm off the dividing wall. is it possible for the wastes from the wcs to use the same waste pipe via a double branch of some sort or do the wastes have to be offset in some way? Thanks
Avoid a double branch I have had to change this configuration on a job as when the cistern is flushed it will fill the pan you will need to offset the connections have a look the attachment, page 18 shows how to do so it works.
You might find this type of fitting useful
a corner branch pipe in 110mm.
Reply to the thread, titled "Wc pans Positioned back to back" which is posted in UK Plumbers Forums on Plumbers Forums.
Dobedo,
king of pipes,
