WC Soil Pipe Connection
View the thread, titled "WC Soil Pipe Connection" which is posted in Boiler Advice Forum on UK Plumbers Forums.
L
Leoki
Hi All
Some advice please if anyone has the time. I may need to replace an existing low level wc for a customer in the next couple of weeks. The wc is a normal wash down but unlike wc's that I have worked on rather than the spigot coming off the back of the pan terminating on the horizontal to which you would then use a pan connect, this wc has what I would call a swan neck which then goes straight down into the soil pipe but here is where I am a little unsure. Where the wc connects to the soil pipe it has a cement collar to create a seal between the soil pipe a and the spigot from the wc.
What would be the best way to proceed to replace the wc ?
Carefully chisel the cement from the collar. this will be salt glaze pipe under the floor most likely so try not to damage it. I use a narrow scutch chisel for this job as it gives you more control of what is breaking off. Dont drop bits down the pipe when you release it. Hope this helps.
Reply to the thread, titled "WC Soil Pipe Connection" which is posted in Boiler Advice Forum on Plumbers Forums.
Leoki,
Terry_the_piper,
