May 25, 2019
DIY or Homeowner
I am putting a shower in, but cant fathom what connector I need to use to get the mains water supply connected to the valve.
The water coming into the valve will be via 15mm pipes, but the opening at the moment is bigger than that so I need a reducer or something for this I think.
I'm aiming to connect using speed fit fittings
(See attached image)
Can you advise?
This showed up when I searched male iron:
https://www.NoLinkingToThis/p/tecti...e-iron-coupler-15mm-x/784fj?_requestid=450208
I'm not sure it is the right size to screw in though.
