A
artie guber
have posted a picture of a brass connector that screws to the top of my pump (there is an identical one at the bottom)
there is a slotted screw in it as you can see - what does this do? Is it an air vent screw, or does it turn and stop the flow like a valve?
there is a little bit of calcium (?) around the screw so dont want to panic that i have a small leak
thanks in advance
It is an isolating valve, leave it alone until it is needed for changing the pump.
As stani says.
It's an isolating valve, turn it at your peril.
It will leak forever once touched. (They even leak if you look at them sometimes:cuss🙂
Reactions: 2 people
As stani says.
In fact it's probably started weeping now because we are looking.
Reactions: 4 people
These pump valve's are a waste of space. I cant work out why they are used or manufactured. They have been about for years and are a constant pain for everyone. Always use gate valve type with spindle.
village theres nothing wrong with gate valves go in any boiler house youll see dozens of them all working fine some thirty plus years old . The problem is cheap gate valves fit proper peglers or conex and they will out last all the 2 quid levers most of which will be leaking in 5 years
Not doubting that. But I have come across many situations where ''DIYers'' or summat go and change a bath etc. Drain down the CWSC or turn off gate valves then once they have fitted the taps etc, find that there's no water to the bath, basin or toilet. Or hot tap works but cold does not. They get paid, pack their tools and leave, failing to recognise that the ball in the gate valve has dropped and will not lift back up to the open position.
I always change them to lever valves to be on the safe side.
