I’m quite sure that it isn’t a legal requirement to complete a tightness on a CP12.
Really? I don't understand how it cannot be the most important requirement.
You are undertaking a series of tests to show that the whole gas system is safe etc. Surely the most fundamental test is to check that the gas is not leaking??? That has to be more important than CO emissions and expiry dates on smoke alarms etc
Reactions: Scott_D
Interesting.
Sure it'd cause a right fuss if you weren't to so one and something did go wrong due to a gas leak though.
Sounds odd to me also, but for the sake of a 2 minute test (plus 15 minutes gaining access to the sodding meters sometimes lol) I'd always do one.
I'd if you did a cp12 and didn't do a tightness test and something did to wrong you'd be on the firing line regardless of law.
Interesting.
Surely you mean a total of 4 minutes 😉😉 and 15 getting access to it.
How can they fire you for something that isn’t a legal requirement? Unless it is company policy.
Hmmmm.
I use the Sprint Mobile App for my FGA and issuing CP12.
There are 3 options on the Tightness Test - PASS - FAIL - NA
If I select NA, then the cert passes. If I select FAIl, then it fails.
So, Sprint thinks the tightness test is not mandatory. But failing it will cause the cert to fail.
Can someone less lazy than me call GS and settle this?
J
I didn't mean firing as in from your job. More from a having to defend your actions (or lack of) for not performing a tightness test.
Wouldn't take the risk of not doing one personally. I know someone who used to do all the investigations following any gas explosions, co poisoning cases etc. And not having performed a tightness test on a cp12 I'm sure would stick out on the reports and earn a thorough questioning if you were the last one to work at the property.
Reactions: Harvest Fields
Hmmmm.
J
Settle what?
Ask yourself why you are doing the test.
If it’s to make yourself money, don’t bother with the tightness test if it’s not a legal requirement. (Legitimate view - I’m not judging)
If you are also trying to do your bit to help people/keep them safe , do the test.
Whatever you do, unfortunately some people will die due to gas related domestic incidents as things can/will go wrong.
If tightness tests are optional on CP12's
Bottom bullet point. Recommendation only.
You’re welcome 😉😉
You’re welcome 😉😉
Thanks for that.
So to further delve in the the rabbit hole that is this conversation.
To perform flue flow (to and check flue/chimney is clear) on a gas fire you'd be removing it (and obviously checking catchment space dimensions etc).
If you found the catchment space to be full of muck but the job you had attended was only a cp12 and not charged for service on the fire.... Would you vacuum it up or would you advise and charge for a service.
Let the divisive opinions commence! 😛
Thanks for that.
If you found the catchment space to be full of muck but the job you had attended was only a cp12 and not charged for service on the fire.. Would you vacuum it up or would you advise and charge for a service.
2 things here. You would call the landlord and get permission to service whilst on site and get paid extra for the service. Also, if you have removed the fire you need to do a tightness test as you have broken a gas connection.
Reactions: Mastermixlee
I agree with Harvest Fields.
Get permission to fix the problem or....1) Cap off the gas fire or 2) Fail the CP12 and cap off the house.....hmmm
Get permission to fix the problem or....1) Cap off the gas fire or 2) Fail the CP12 and cap off the house...hmmm
Talking of which.
If you cap a gas fire due to spillage etc then that appliance has failed. But if capped then risk is removed. So cp12 still a pass (overall)a fire is technically decommissioned? *Insert thinking face emoji here....as they don't have it on the forum 🙁 *
