Hi all just picking your brains 2 pumps with flow rates of 3.8 and 5.7 which is the more powerful, also can you fit a commercial pump into a domestic system?
Hi John no the Alpha 2 it just has 7 different levels depending on what type of heating you have, power flushing is done by a machine that contains chemicals and uses a bigger pressure than mains pressure but at a low flow rate, when it's finished inhibitors are put in and you end up with a much cleaner system, a bit pricey but worth it, when it has been done as i said I am going to fit a magnaclean and that should prevent any new magnetite from forming.Excellent news, I will have a few extra drops of Jamesons tonight not to mention a rake of Guinness.
Does the Alpha 2 display values as well?, W (watts) will do fine. If so, when you get a chance you might run it on CP2 which is 3M and post the values, or/and any values you have just now, that will give a very good indication of how clean the system is.
What exactly does a power wash achieve that you havn't already achieved, or how does it work??. you can flush out each rad individually in your own time and add inhibitor when all is done.
