M
Mbear
We're Pricing heating for a small church hall (rough size - 3/4 of five aside pitch)
Hall is upstairs, boiler being fitted at top of stairway adjacent to hall, 8rads in total...
6 on one level along with boiler and pump (upper level) and 2 at opposite end of building from boiler at ground level. My worry is with the last 2rads and distance away from the boiler/pump, I'm concerned about the heat getting to them and gd circulation back to boiler. If these two rads weren't in the picture then I'd happily go for a 15/60 but as they are then I'm swaying towards either 2 x 15/60's (one flow&one return) or one 25/55. Cost wise the 2 smaller ones would be better but cost isn't really the issue, the correct pump or pumps is needed regardless of cost. Rads are all between 1000 -1600 long and pipe size I've already decided 22mm From boiler all the way to every rad and with 15mm tails at each valve.
Any input is appreciated, this is a slighter bigger job than we'd usually do, ta
