View the thread, titled "Who owns a multi cutting tool? is it worth getting one?" which is posted in Plumbing Tools on UK Plumbers Forums.
armyash
Subscribed
Just putting a list together for some tools that I don't have.
Who owns a multi cutter? Thinking about getting one.
Might come in handy when tiles need a little bit cutting out, yesterday I had to cut a section out of a crappy ply wall and the only way I could do it was with hole cutters and jr hack saw. Might have been better with a multi cutter.
Worth getting?
Any recommendations?
Thought I'd update.
Just picked up an Erbauer multi cutter from Screwfix. Seems decent, I dont mind Erbauer stuff, I have an erbauer impact driver and it's tough as nails and powerful. The multi cutter feels just as good.
Found screwfix vouchers i'd had in the van for ages from christmas and used them to pay for it. Bonus!!
FEIN 72363650243 Supercut FSC2.0Q 230v and Case QUICKIN Version
The Fein Supercut, proper amazing tool. Pricey but more than worth the cash for the time it saves. The Multimaster is just as good for cutting open stud walls etc but the Supercut wins hands down cutting through floorboards/chipboard etc.
Buy the 3rd party blades off Ebay. Shark blades I think they are called. No need to buy the rip-off Fein ones at all.
Thats twice the price of the top multimaster!!
Interesting to hear as was looking on the fein website the other day and noticed the different models
Much faster for cutting floorboards etc. Motor has enough power to cut through chipboard pretty easily, From my experience using the Multimaster (owned 2 of them before prior to buying a Supercut) it tends to struggle on this and the blades overheat quickly as a result.
The Supercut has a 400W motor instead of the 250W motor in the Multimaster. This means the blades will last longer. The Supercut has a much better fixing mechanism to hold the blades in which means less power is lost prior to getting to the blade and it also means the blades last longer again.
Well worth buying if, like me, it's a tool you use every day. If you only use one occasionally like I did when starting out the Multimaster may be a better option.
PS - If considering buying their wetvacs - Dustex 40 and 25, do not buy them. The hoses are not designed to take 60 degree water from heating systems or hot water cylinders. Ours collapsed in on itself the first time we did this. Shame as the design looked great but it just didn't work in practise. Went back to Numatic wetvacs in the end!
The Supercut has a 400W motor and a better mechanism for holding the blades in tightly which means much less wear on the tool. This also means the blades last a lot longer too.
Actually I have noticed the multi master burns through blades, and they ain't cheap.
The Supercut doesn't really burn through blades at all to be honest, certainly not on anything I've cut yet with it. Clearly if you tried to cut a brick wall it might but for wood and plywood/chipboard it works a treat. You can't use Multimaster blades in the Supercut though so make sure you use all the Multimaster ones up before upgrading it. The Supercut has a different blade engagement spline on it.
Don't just take my word for it, joiners use them all the time - read their reviews here - http://festoolownersgroup.com/other-tools-accessories/fein-multi-master-or-supercut/
This is where I get my Supercut blades from - the blades seem to last forever unless I hit a nail, then they are ruined!
Replacement Blades for Bosh and Fein Multitools
Really? These things are like ultrasonic toothbrushes with a blade, fair enough for occasional or even difficult jobs... But day to day floors and stuff? Use a rip snorter or recip (hackzall) it just seems like your using the wrong tool for job because it's a novelty? Analogy would be using a toffee hammer to knock out a flue hole? And the noise. I'm not saying they are not useful as sometimes they are awsome but using them as your main mechanical cutting tool, yet to be convinced.
If I'm doing a full system I use a circular. But for lifting a small amount of boards, I'll use my fein.
The main reason I don't like using my circular is sheer amount dust and shavings the bloody thing throws everywhere!
We don't use them as our only mechanical cutting tool but they are used on nearly every cutting operation we do at some point.
For lifting chipboard or WBP Plywood flooring we use a circular saw as our main tool like most will do no doubt. The Fein is used to cut the corners neatly, avoiding having to overlap cuts like you need to with a circular saw.
Equally, when replacing a chipboard floor in a bathroom the Fein will be used to cut the flooring flush with the walls where it runs under them. Again, this is impossible with any circular saw or other type of saw on the market.
The Fein is the fastest way I have found to lift individual boards in a floor comprised of tongue and groove floorboards. No circular saw or any other tool necessary here.
Cutting copper pipes where you can't get a pipe cutter into, just whiz the Fein through them then deburr with a file. This has got me out of a difficult situation on many occasions.
Trimming architraves that are already fixed in order to fit a tiled floor under them, use the Fein again.
Removing skirting boards, now a quick job. Cut them down the middle then you can easily pull each piece out. Even better for removing them behind radiator pipework.
Cutting into a section of tiling on a stud wall to create an access panel because the previous plumber never bothered with them, just use the Fein again and cut straight through the grout line.
Not to mention how much tidier they are than a circular saw - because of how they cut and the thin blade very little dust is created.
I could list so many more time saving uses for this. It's the best tool we own.
What he said.
Good argument, joiners got one cut a few skirts and stuff , but my memory is of the awful noise? Think the bloke I'm recalling had a cheap one but I was in the floor viid and it was actually painful. Can do main cut and all the jobs u mentioned with hackzall but it does "bounce " being a bit cynical as I'm trying to prevent myself buying more toys! Welding kit and accessories took a lot of self control. Bit like Kyle in Hilti shop
just bought the makita 18v multi tool probably the best tool i own, its easier being cordless and my boss has got the 240v fein and there is no difference in performance I've got the 4ah batteries though it lasts forever well worth the money especially with the 3 year warranty
You know you want one, no! Need one.
If in doubt, buy the 240 volt Parkside multi tool from Lidl & give it a go when the needs arise. It feels good in the hand & is fairly quiet.
Only £35 & includes set of various blades, so nothing to lose!
Reply to the thread, titled "Who owns a multi cutting tool? is it worth getting one?" which is posted in Plumbing Tools on Plumbers Forums.
Thread starter
armyash
Subscribed
Joined
Location
Kent
Thread Information
Title
Prefix
N/A
Forum
Plumbing Tools
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
tool
armyash,
PlumbBobBob,
