In real life no-one isolates the boiler, drains it down & tests / pump up expansion! Plus then opens the prv to check it operates!
If the pressure is stable, with no high rise & the customer confirms no frequent top up then that to me confirms an okay vessel!
If I isolate the boiler, the valves will probably start leaking. The schrader valve will then start passing, the prv will continually drip after opening & the customer certainly won't be thanking me for now saying I need to replace parts!
I think with knowledge & experiences engineers can tell alot about the boiler without following books by the letter!
Its like the old boilers that tell us to completely strip the boiler, removing fan, burner nozzle, etc etc, we don't do those parts either if its going to break seals that we then have to source & replace!!
