lordyjordy111
109
11
18
Guys
Worcester 34cdi combi
Gc no 47 406 36
the heating works fine.
On hot water the boiler temp builds to 100 and cuts out. Obviously hot tap goes cold.
As heating was working fine and stays around 70 I decided it must be the plate. Presumed pump ok as well
Changed the plate heat exchanger and fired it up.
Does exactly the same thing.
anyone got any ideas......
Cheers
I always try and check the flow and return where they attach to the plate I've previously had a blockage there
  • Useful
Guys
Gc no 47 406 36
Cheers
Is it an old one by any chance? Pretty sure we've had this before and it was the modulating pump not working correctly. I'll have to check as it's a good couple of years ago but sure the issue was very similar.
Those plates are so unnecessarily frickin long in a small space to get out not the best design.
