Worcester boiler not working and flashing 'EA' error code
View the thread, titled "Worcester boiler not working and flashing 'EA' error code" which is posted in Boiler Advice Forum on UK Plumbers Forums.
My Worcester Greenstar 29 CDI boiler made a loud bang earlier today, and has now stopped working.
It is flashing the 'EA' error code, which according to the manual, means no flame is being detected.
I tried resetting the boiler a couple of times but upon doing so, it just makes an extremely loud vibrating/humming noise intermittently, and then turns off and flashes the EA error code again.
Could anyone advise what the issue is? Boiler is only 3 years old. According to the manual, the EA code means either no gas in the house, frozen condensate pipe or blocked flue outlet.
Wondering if this is something I could fix myself or if I need a gas safe engineer to come and have a look
Under warranty min 5 years if you have gas and power time to call Worcester out
You can fix yourself if it’s a lack of gas, by which I mean if you have a top up meter and have ran out, or Network has been turned off.
Anything else gas engineer/Worcester warranty required.
Edit: Check your emergency control valve - been to 2 recently where they had been accidentally knocked off.
Reply to the thread, titled "Worcester boiler not working and flashing 'EA' error code" which is posted in Boiler Advice Forum on Plumbers Forums.
superman876,
Harvest Fields,
