Petefinny
Can any body help me wire this up I've got the live from the fuse spur to the live on the box then the neutral to neutral, them where does the LR LS NS to on the boiler? Does it still need a live and neutral to the boiler or does that come from the L1? First time I've touched one
Not familiar with a boss therm stat but wireless thermostats are normally easy too wire up especially with worcester boilers as the MIs are very detailed.
have you wired in the receiver?
Yes the reciever is wired up and showin power its just that I'm gettin none to the boiler, its from the box to the boiler I want help with, Thanks
LR, LS, NS are right next L,N,E connections. Your boiler will still need power on the L,N connections and then then power taken to the receiver either from the boiler or via the fused spur. I'm guessing I've understood your question right?
Edit
The LR, LS, NS will just control the heating demand on/off, the boiler still needs the power from the spur.
Wire boiler from mains to live neut and earth. Then take the live and neutral from there to the receiver live and neutral take LS to LX and LR to L1 job done
Ps boss therm are actually really good stats for the money you pay made by Siemens under all the branding
Have you got it sorted now?
I find drawing the set up/wiring on a bit of paper a bit easier to follow for when your on the job doing it. I think it makes it a lot quicker to follow, just don't let the customer see it
M
Boiler Advice Forum
Deleted member 120897
