R
richardd
I have wired a worcester with a permanent live from the fuse spur ( that also controls the honeywell controls ) direct to boiler . I have also wired in the honeywell smartfit ( splan ) wiring center (from boiler to wiring center )
When I select for everything to go of on the internal programmer in the house the worcester dosent go of and just keeps the house at 21 degree. If you want to turn the worcester permantely of you have to do this at the on/off at the boiler which is installed in an outhouse ( a bit inconvenient ) do you guys think I have wired this wrong if so what is the problem.
