Wozza
View the thread, titled "Wozza" which is posted in Central Heating Forum on UK Plumbers Forums.
Flue Snugs
Hello all new member here.
Flue snugs. I’m seeing a lot of boiler installs on you tube that don’t have flue snugs to comply with Part L building regs.
What are the rules regarding flue snugs, do they have to be fitted on all new boiler installs.
I prefer to use sand/cement instead of paying £40 for 2 flue snugs
Some Manufacturers like Baxi have a flue snug flue collar option however when I purchased there new combi model recently I was still given the multi fit flue with rubber flue collars. I asked them why and they said I have to request the new style flue snug flue collar instead of the multi fit version.
I welcome your views on this
Wozza Gas Safe registered
The flue from baxi only fits on the combi 2 no other boiler in there range
Thats correct so does a
@ShaunCorbs thanks for your reply That is correct , im hoping someone can answer my original question on flue snugs being required on all new boiler installations mandatory thansk
It’s a nice optional extra but new build arnt doing them also have to core a 6” hole
I use low expansion foam for air sealing the flue
Hey and welcome Wozza
I have moved your thread to a more appropriate forum so you should get more replies!
Welcome!
I forgot to say PM me your gas number and business name and I need to give you access to to=hose areas of the forum.
Reply to the thread, titled "Wozza" which is posted in Central Heating Forum on Plumbers Forums.
Wozza340,
Lou,
