Dec 15, 2018
105
28
28
DIY or Homeowner
Hi, I have a Y-plan 3 port valve in my system, no idea of make, it's been installed for a number of years has been working fine, but now I've had a new boiler fitted it seems to be a lot more sensitive to temporary interruptions in flow, e.g. when the valve switches between mid position and heating only, the boiler shuts down for a few minutes before eventually firing again.
I suspect it's because when the valve is turning it momentarily shuts off the flow to both mid and heating ports - my question is would a newer valve solve this (i.e. are modern valves designed not to interrupt flow whilst turning)? Or would a bypass solve this (I don't have one)? Or should I just not worry about it?
The increased off time will be an anti cycling feature of the new boiler. It won't be the flow but a momentary interruption in run signal to boiler.
Is this behaviour normal on a Y-plan system?
Would prefer if the boiler stays lit whilst the valve is switching, but doesn't sound like there's a lot I can do about it.
