N
nysk2008
not worked on these and not seen it but gotta change a auto air vent on an alpha cd24c, easy enough job?
cheers
cheers
Never worked on the good old mynute se then?Never worked on these boilers but it will be easy. I'm yet to find an AAV that's hard to Change
Just a straight forward easy access job IIRC.
very similar to a ariston microgenus set up,you can unscrew it but try getting the bobbin outTop of pump is more or less flush with bottom of burner with the AAV on top of pump protruding up at rear of burner.
It is possible to change insitu but the easiest option is to remove pump.
