derryk
Hello, can anyone advise an amateur.
I have underfloor heating (hot water from combi through plastic pipes) on 2 floors of a 3 floor semi + 4 rads.
combi pump died, BG fitted new and advised fitting a magnatech 2. I've searched spirotech.co and found they now do a mark 3 model. So ok i can fit this (it's only a bit of pipe to cut).
My questions are :
After i drain down and fit the filter how much cleaner and then inhibitor should i add ?
how long should i run the cleaner liquid before draining and filling ?
Is there anything else i should be doing ?
thanks derryk
My questions are :
thanks derryk
