Discuss Chlorination of 63mm mdpe incoming cold mains in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sharp Point
Evening folks, I'm about to commence work on a 8 bed new build dwelling, the custard has just emailed me, asking if i know anything about how the incoming mains from road( about 130 metre run). Is it a requirement before or after Anglian water connect it in the road? I've carried out chlorination of schools in the past ( very boring job) but how is it carried out pre or post connection? Do you need a special qualification to sign off a clean out?
dont the water board do it after they tap in?
flush n go, its domestic isnt it? dont suppose your storing cold water in a new build
i would just get a firm in once the main is in and ready to flush, they will supply the test certificate needed for the water board.
I think you & your customer are in for a bit of a shock unless things have changed in the last few years. Once you go over 50mm on mains the pipes need to be swobbed out by pulling a chlorine soaked rag through the whole length of it. The trench will need to remain open until they come & inspect it, thats all before they make the connection.
Just had a look at snowheads link, oh yes forgot about the samples as well, as others have said get a firm in but be prepared for a hefty bill.
Can you self-cert the internal stuff ? otherwise you may want to check out the water supplies T&Cs, Thames wanted min 10 working days to come & inspect the completed install, then up to 21 days before they would do the connection bit of a long time to have a completed house without a water supply (hope they have a temporary supply?
the best thing to do is get friendly with the local inspector and follow whatever advise/ orders he/she gives you.
live n learn, seems a bit ott but rules is rules
Our guys who install the main network on sites have to chlorinate their tools as they work & are not allowed to work if they have some every day infections.
I was not aware of any of this until I started this new job. Every days a school day.
Reply to Chlorination of 63mm mdpe incoming cold mains in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
