Discuss cracked cistern in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Poynton Plumber
i have a cistern that has developed a hairline crack right down the back.
the water is seeping out, at the rate of about 10 drips a day!!
i want to have a go at sealing the crack before doing the obvious and replacing it.
any suggestions as to what i could use?
my first thoughts were silicone or a flexible/waterproof epoxy glue
ct1 silicone, google it.
also check it out on youtube, it will certainly do the job until you replace it, wich really should be sooner rather than later:)
thanks for that andyg0507.
yes i'm coming round to the fact that it will have to be replaced.
Don't leave it. It might suddenly go in the middle of the night!
turn off the service valve to your wc and replace it, the ÂŁ2000 damage it will do when it breaks and floods you out isnt worth the wait
i have been running an experiment on my cistern for the last 8 years or so, old victorian one.
it has a 10'' crack to the front of it with a smear of silicon inside and out, it is also boxed in so not seen but still no leaks. i will let you know when it fails for research purposes.
i have isolated the cistern and emptied it.
also advised the customer that replacement is the best thing
thanks for all your advice
heres me thinking you were asking for yourself as a diyer lol
, yeah always replace when it comes to things like this - not worth the eventual claim against you as you were the last to try and fix it.
new cistern on it's way today.
suprisingly the supplier has agreed to replace it FOC.
was fitted only 9 months ago, but unusual for supplier to replace.
The supplier has done it for goodwill. In any case they will just send it back to the manufacturer and be credited for it so no loss to them.
Reply to cracked cistern in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
I'm trying to change a dripping cartridge in a Franke Panto tap. I have a new cartridge and after a fight involving a decent hammer I've managed...
7K
Pauline Wilkinson
  • Locked
Go on then I'll post in the proper sub forum I suppose.......... Fitted a bathroom suite a few weeks ago and I'm going back to do some other jobs...
9K
E
  • Locked
I took out a comfortable well crafted 45 year old toilet and have replaced it with a crappy new one. (WOMEN !!) Toilet and cistern coupled...
38K
L
  • Locked
I have just fitted a new close coupled w.c. I followed the instructions when it came to fitting the cistern to the bowl, e.g i noted the order in...
18K
REDSAW
R
