Discuss Get a Pro silicone finish in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumber0808
Purchased a Fugi kit today and used them on two bathrooms.
i am decent enough at getting a good finish and have tried all the tools to try and get it looking perfect.
A bad silicone finish can ruin a bathroom, there easy enough for anyone to use and a produce really good finish. £11 from toolstation which I thought was a bit steep for 3 bits of plastic but they are top class.
Toolstation > Adhesives & Sealants > Sealant Tools > Fugi 3-piece Profiling Tool
I often wonder, as so many are now using flexible connectors, and I know most on here hate them, if one should silicone finish the area behind the taps and then fix the taps afterwards.
Good idea, but everyone says you should fill the bath before siliconing though!
I always do this
I could be wrong here but I don't see the point in half filling a bath before siliconing.
When I install a bath it's on batons at every point possible and wooden supports if there's a corner that doesn't hit a wall. My baths are solid and I could bloody jump up and down in them and they will not move.
Now for that reason I do not bother filling before siliconing
yep I am another, I have never filled a bath ever to silicone (I would end up in it!!). Same again with the taps always put them on last.
I have been using this kit for years and love it. The kit I bought has the 3 pieces shown plus a further 3 for different sizes of bead plus 2 gizmos that clip on them for going over grout. I would recommend it to anybody, it makes the job dead easy.
I looked at the fungi tool the other week,I think I will get one if you guys rate them.:D.
Ive been using them for years and dont know what i would do without em!
I still struggle on cotners with these. Especially shower trays which have all the little joints in them. Jad a job today to do and re did it a couple of times. In the end I still wasn't happy withbit but ran out of time. Also, it does get caugjt in the grout lines a lot which messes it up a bit. And, if the walls not square it's a bit of a mission
Tilt it across grout lines so that it doesn't sink into them. Takes a little practice but the finish is worth it.
I'm too tight to spend a tenner on anything mentioned, so I use the back-end of one of these.
wet wipes with citric acid in,you don't need bits of plastic wilkos own brand are about 50 p and they work fine
Yeah and when the citric acid gets in the cuts in your fingers it's almost as nice as flux getting in them
I fill a bath with tap water first to weigh it down, yes I use battons and always glue a bath to the wall with silicone but baths are so thin these days and people are heavier there will aways be small degrees of movement in the acrylic and dodgy silicone seals are always the main cause of water through ceilings.
so that's what those black plastic bits are for. What do you do with them?
Oh laco burns. Especially when your hands cut to bits and your wrestling a flux covered fitting!
Yeah burns even more in your eyes!!! Was fluxing a fitting in an awkward position under floorboard flicked the brush bit too quickly, blob of laco straight in my!!!!! I genuinely thought I was going blind ! Freaked the feck outta me!
I ended up in casualty about a month ago. Solvent welding a pipe and flicked the brush towards me, and straight in the eye....I was wearing glasses too, so very unlucky. Got to the hospital and had a lovely chat in the waiting room with a stone mason, who had previously got acid in his eye and had his eye removed to be cleaned and put back in! I crapped myself. Luckily no harm done to me.
wuss,its nowhere near as painful as laco
If you want to know what real pain is.
Do as I once did: Go for the p**n star look and lather your scrotum in Veet hair remover.
I'm shedding tears now just thinking about it.
the fugi kit is cheaper online and comes with extra bits that you dont get at toolstation.
I have been using those fungi kits for years and altho expensive you make your moolah back straight away when you reseal a bath.
Got solder on the rim of my eyelid last week, Christ did it burn but just glad it didn't go straight in eye
Feel your pain brother, I used nair on mine and left bit too long, no word of a lie the crease in my groin was bleeding, worst pain ever
Indeed, was only soldering a rad tail but I'm pretty short! Worst thing is keep wiping my cos sweats getting in it and every time irritating the burn
put some vaseline on your eyebrow stops the sweat rolling down onto your eyelid, job done !
You mean you haven't worked it out? Me neither, but I believe that's what they are for. Help anybody?
I just tilt them slightly at the grout lines.
I invested in a set of these, they work so good. Surely make the difference!
after applying silicone with a gun slowly and tidy with the nozzle cut at 45degree ish close to the tip. I spray around the bath with soapy water on top of the silicone , run your finger on it then, fantastic finish , excess silicone curls up your finger , only takes 5 minuets to do a bath, and I feel that you push it in all the gaps better with your finger, rather than scraping it off
I used to use the above method, until I discovered Fugi tools. They are very wasteful and do scrap it away but it's definitely pushed home and sticks well....plus it looks the total dogs dangles, chamfered off at 45.
They are really good.
got some somewhere and used them once....
there a waste of time imo.
i use a £1.50 delta tool and can do a bath in 3 mins flat.:wink_smile:
Reply to Get a Pro silicone finish in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I had to remove the glass panels from this quadrant shower cubicle and I'm struggling to get one of the screens back in place properly. The...
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A...
Hi Firstly apologies for this not being directly a plumbing question, but I'm in a bit of a bind and I was hoping to find some help. It's more of...
2K
Hello all, I'm looking for suggestions on heating controls. We'll be upgrading our boiler (To a modulating oil system boiler - EOGB Sapphire)...
5K
