  • Thread starter Barry98
  • Start date
  • Replies 3K
  • Views 593K
Discuss HALL of SHAME PHOTo`s in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Came across this. Garden hose for a PRV pipe off a combi boiler. Jesus wept.
Why bother moving the copper radiator pipes to the proper place nice and neat?
Just get a builder to do your bathroom and leave the existing copper pipes and do this, -
Yes. Rest of job (plastic wall paneling etc) looks okay. Surely a little effort would have moved the microbore pipes below the floor and brought up copper 15mm neatly and directly to towel rail. I didn't need to ask who recently did the bathroom. Had to be a builder.
Hahaha that's a cracker :)
Pressure reducing valve has been fitted on lower floor. Going to be fun servicing it. :smile: Relief valve obviously wrong place also. Whoever did this work definitely is capable of doing copper pipes and soldering neat, but I can't understand why they have the heating pipes to coil just straight out from connections taking a lot of space up.
View attachment 26605View attachment 26604
wheres the expansion vessel?
Think that's a megaflo so it's got the internal one
Yes, it is indeed a Megaflow, so as you say, it has an internal air gap.
Workmanship not really deserving of Hall of Shame, but pity the plumbers couldn't have done it better and to proper unvented rules. The combination valve shouldn't be elsewhere and the separate pressure relief valve and its d1 needed above and dropping into tundish
sorry for bad light the sun was out :D
:D
mastic every where holding the flue onto the unit and holding the bricks inplace
Thoughts
Thoughts
Ffs wrong way
Can you not get inside to see where they put the boiler,
I was sent this photo.
I hope the air vent is on the right hand side.
Always try to use short pieces of chromed pipe from chrome towel rails valves to keep the finish professional
I bet those bends were off of the original system, have to admit the bloke must have known what he was doing (if it works) because I get travel sick just trying to trace it!
Before you ask, no I didn't. That was the colour of the water coming out of the tap!
Builder-Got any 4" fittings on the van?
Plumber - got a few odd and sods.
Builder-couldn't let us have some?
Plumber thinks - thought I'd never get rid of those old bits.
Builder- Doesn't look to bad does it?
Also, -
Builder, - "Sure the home owner will be painting it anyhow!"
Reply to HALL of SHAME PHOTo`s in the Plumbing Jobs | The Job-board area at PlumbersForums.net
