Discuss I will need a help to chase a part in the Plumbing Jobs | The Job-board area at PlumbersForums.net
No worries mate. I think both me and ShaunCorbs was just saying that the meter above has to have a flow of water running through it and the temp gauge that you are fitting is in a dry pocket, but only reads the temp not the bars. As for the gauge to read the bars it would have to be in a wet pocket. If I am wrong then I am open for you to explain this to me.
Harvest, you both don't get me. I have not changed the gauge at all. The dry pocket I have changed is the one for the sensor for the sensus meter. All meant was, that the customer had a broken meter. I went out and changed it but when it came to pulling out the sensor from the pocket it was not that easy. The customer just grabbed a tool of mine and tried getting it ou and ruined the old one which was copper. Now I have installed a new brass pocket. I have read that the meter reads easily temperature. But also too, he can easily find out how much they use to bill them. So somehow the meter must be able to read how much water they use.
I'm going to say. I have too much beer to reply properly to this message tonight. So I am going to agree with you and say good night..
So. Good night:D
Reply to I will need a help to chase a part in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a kitchen mixer tap which allows the top part to pull out as a hose (like american sinks). It has frayed and I need t replace it, can...
I have a "Firebird Envirogreen Condensing Combi Oil Boiler 26kW" a part has went and I can't find it anywhere, I was at every plumbers merchant...
Hi guys. I've been running an UFH installation/ repair business for 7 years now and one of my main frustrations is finding the parts for the UFH...
I need to extend my central heating from my newly built extension in to the old part of my house. I need to feed 3 rads in separate bedrooms on...
Hi, I have a radiator which is unbalanced; I believe due to a missing outer part, please see the attached images. Is the missing part called a...
