Discuss Internal reducer help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
lewissv
Hi, I am fitting a towel rail in place of a radiator. I had to use an internal reducer (15mm-10mm) to connect up the pipes to the towel rail.
When I filled up the system again both valves were leaking.
Do I also need to use a 15mm olive on this?
At the moment I have;
the copper heating pipe, with the smaller reducer on it. Then the small olive, then the larger reducer (which fits inside the bottom of the towel rail valve). I think this is where I may have messed up, do I need a 15mm olive in there too?
Thanks,
You should have one reducer in the rad valve that's a appropriate for the pipe size. It replaces the olive in the valve.
Sometimes you have to tighten the nut on the valve until you hear a little click. It feels like you're over tightening it but you're not.
Thanks Mushybees, I have tried that and one valve is fine now. But I have dropped the reducer for the other valve and it has disappeared under the floorboards - looks like it is lost forever! Back to the plumb shop tomorrow for supplies then I can finish the job - and a lesson learnt - cover up any holes as they will attract the essential fittings needed for the job!
Thanks,
Reply to Internal reducer help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, I need to replace a radiator in the kitchen, the 10mm copper has split so using this opertunaty to replace it with a towel one and also...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the...
I have a question that I’m hoping those of you who are experienced central heating engineers may be abler to throw some light on. But first I need...
Hi, I have a leak on the live side of one of my rads, in the GF loo. Its a condensing combi system, the house is only 5 years old, so fairly new...
1K
