Discuss Power flush in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
cardigan
What's a 'power flush after a new CH boileris installed?' What's involved, how long does it take and what does it do?
TIA
this is to prevent debris damaging boiler components, but it is usually done before the installation and it is good practice to fit a central heating filter to prevent further damage
Dear God, how the hell can they charge that much for a couple of hours work flushing a system?
Its not just a couple of hours though. I've been on flushes that have taken all day. Then you've got the cost of the machine itself to pay for, then the cost of chemicals and specialist tools you may need, plus you need to cover your costs should any unforeseen problems arise from doing the actual flush.
Straight out of the British gas handbook... :30:
the machine and equipment costs ÂŁ1200 to ÂŁ2000 and it takes between 4 to 8 hours to do on average. You have to pay for your van, your PLI, your fuel, your other business running costs etc......
as the saying goes you get what you pay for. :)
best to steer clear of large companies and use a local engineer, get some quotes.
im not particullarly cheap im about ÂŁ200 more then most people in my area but im there all day fit a new pump and mag clean, use good chemicals and nutralise the system after if ive had to use a heavy chemical. oh and i remove the f&e tank wash it out and loop the f&e pipes in with a isolator so they all get cleaned too.
there are still many who disagree with power flushing and im sure some will be along in a bit. but i do it and see how much comes out and there is no way on most of the ones i do a normal chemical clean would touch them.
You can hire a professional powerflush machine for fifty pounds from HSS Hire (February offer), anyone of average intelligence who can read can do it - you need to be fit enough to climb up into the loft, and not prone to dying of boredom.
First time round with 12 radiators will probably take around 8 to 10 hours.
But it is true
Im only messing. Power flushing done correctly is a long and extremely boring task but well worth the expense in my opinion. If its rushed and not flushed thoroughly it's a pointless exercise.
That's all we want - a decent job for fair price; is that too much to ask for?
what do you think a decent price is?
the average price is what ÂŁ300-ÂŁ500at a guess dependant on area and work involved.
for a good days labour from a skilled tradesman with all the costs involved probably making a wage of ÂŁ150 for the days work.
seems a good price to me, my car garage charges ÂŁ95 per hour labour, that over 8 hours is ÂŁ760 for labour then parts ontop.
what quoted prices have you had? maybe somebody on the forum lives near you and can give you a price?
Outside of London you will be able to get it done for around 300 pounds.
British Gas charge as much as 800 pounds, and say they guarantee it - which actually means they will then include the water in the system under a Home Care Service contract - which is around 20 pounds per month. End the contract, and the so called guarantee ends too.
If its that lucrative why arent you doing it youself ? If you run your own business like many people here then you will know that you dont trouser everything you charge and have overheads to pay for.
I bought a Kamco power flush machine 2 weeks ago and got it brand new for ÂŁ1080 and the Kamco guy told me I got a really good deal as they charge ÂŁ1020 + VAT and then I will be buying more equipment as I go like the magnetic filter and pump head adaptor. As you can see there is a big outlay!
I agree tom. Mind numbing job but its money for old rope once you've got the gear.
its the first thing that gets connected once drained down return flow linked while one cracks on with the install of boiler
You do it cold then lee? How do you find time to run round all rads while fitting boiler?
The truth is that everything to do with powerflushing is overpriced, starting with the machines used, which basically comprise a pump connected to a plastic tub, with some valves, and a few pipes. 1k+ is a ridiculous price for something so simple.
The 800 pounds charged by BG is also a ridiculous price, but in the free market it seems there is no such thing as overcharging - 300 quid for the powerflush, and 500 quid for the BGBS!
The return on initial investment, even at 300 pounds a throw, is very good on a piece of kit costing between 1k and 1500 pounds.
Powerflushing is a first year apprentice job: requires the ability to use a wrench, a few grams of common sense, and the ability not to fall asleep on the job. Recognising the risks with a weak system is probably the most skilled bit involved.
Anyone looking for a low-cost start can set themselves up in business with a small van, an overpriced powerflush machine (with a one day training course), and enough business acumen to get the show on the road.
Thats really helpfull on the open forum.
Can't see why it should be a problem to anyone pricing up jobs competitively - not so good for BG maybe, but then there's plenty worse about BG on this site.
Anyone shopping around will find that what I have said is more than reasonable - I think there are quite a few people on here out of touch with the going rates for such work, which might help to explain why they are sat on the net instead of working.
I'm very busy thanks. Encouraging people to start up in power flushing! Personally I think it's more skilled than you make out. Different size rad valves, different types of boilers. Some of which can be damaged if not prepared correctly, running boilers dry, getting rid of air locks, etc, etc.
Have you read the rest of the thread, the majority of the posts are in a similar vein - "lackie does it' ... "money for old rope" ... etc. Strange that you think I'm giving secrets away!
I do think it's a good investment for anyone starting out, such as people with level 2 NVQ and the like, who often post on the board - what's wrong with that?
Doubt that I've triggered a wave of start-up new businesses in the UK that are going to drain work away from the plumbing trade.
Doubt that I've triggered a wave of start-up new businesses in the UK that are going to drain work away from the plumbing trade.[/QUOTE
So how are these new people supposed to know what causes the symptoms for needing a flush in the firstt place?
Reply to Power flush in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
  • Sticky
We have 2 brand new cordless, battery powered press tools in stock, and flying off the shelves. Our TekTools TZ1930 & TZ1550 are packed with...
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
