Discuss Should i use Ptfe tape? in the USA area at PlumbersForums.net
Firstly im fitting some basin taps, ive now got the washers. Should i use ptfe tape on the basin tap tails/extension threads? If i should how much should i put on?
Thanks Andrew.
I presume you have flexi pipes connecting to the taps like this:
https://www.NoLinkingToThis/p/flexible-tap-connector-with-valve-15mm-x-x-300mm/3558g
Flexible tap connectors have a rubber washer and PTFE tape is not needed.
No they are 1/2 extenders because the new taps have shorter tails. When i put them on without the fibre washers they were leaking, sorted the washers now.
Reply to Should i use Ptfe tape? in the USA area at PlumbersForums.net
A
Both Tiny leak on bot new fits on the metal nuts. Did i use too much ptfe tape. I used 2 wrap arounds. The nuts won't tighten anymore. Could i...
I'm at the stage of my shower replacement where I have a new shower head to screw into the wall pipes. I tried it, turned on the shower, and find...
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems...
Hi, The isolation valve feeding my toilet cistern was leaking. After considerable effort, I was able to lift up the cistern to put an O-ring...
1K
