Discuss Soldered gate valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
rocketmanbkk
Hi Friends
Got a dripping gate valve to fix/swap.
It 22mm and soldered on.
I don't think there's any issues in cutting in out and putting a modern one on etc.
Never seen one soldered on so I hope I'm not missing anything.
It's in an airing cupboard.
Hope all is well.
Rct
Leaking from the guts?
try changing them out.
if cut you'll be fine cutting a new one in, just makesure you have imperial converters incase
Pleasure.
The soldered gatevalves I've found have mainly been on 3/4 pipe.
i like em :D
Older systems you get 1/2, 3/4 and 1. Not seen any 2" need some tube as well. If it's only leaking from gland do as kb suggests and just renovate.
Reply to Soldered gate valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The...
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
1K
Hi, I thought I'd share my experience of dealing with Aqualisa about their Quartz Digital Diverter. When selecting the slider rail handset the...
Hi all. I hope you are well. Need some advice on this boiler and fault. E229. Went there and condensate was totally blocked so cleaned it and...
Hi I recently did some pipe insulating in my loft. The only two I didn't do were the vent pipes. Not sure if that is the right term for them...
