W
wildobc
Have recently installed a new multi fuel stove with back boiler to heat radiators only - totally a ground floor system. Have used an expansion tank with cold feed and also a 22mm vent pipe to the top of the expansion tank. Have used a pipe stat to kick in the pump and have currently set this at 60deg. The problem is that when the pump kicks in, water immediately vents to the expansion tank (it's clearly not boiling) However, when I close the cold feed valve, the venting stops. Other than that, the system has worked perfectly for 3 days, solving the problem of a very cold kitchen. I have kept a close eye on the venting but if the cold feed is open, the system vents every time the pump kicks in. The bottom of the expansion tank is 1.7m from the 28mm flow with the vent pipe 2m from the flow. Pump flow rate is set at I
