- Messages
- 34,374
- Solutions
- 2
Isolate supply mate
how do you isolate the install?
Discuss Un-sleeved gas pipe, landlord saftey check. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Isolate supply mate
Sleeve has been AR for years when it is straight off the gas meter.just with with sleeve theyve upgraded it from ncs to ar which i dont agree with
By the appliance spur or Gas tap/ECVhow do you isolate the install?
Nope, because you remove the fuse from the spur or turn the gas tap to off position or pull the ecv to the off position (this is not a cap as you can Turn it back on with minimum effort). When you cap something you are disconnecting it from the supply. You only disconnect on an ID. NOT AN AR.so ar is cap the supply
Yeh I get where your coming from I think. If you can't isolate supply appliance without isolating whole install affecting other appliances then you would can it at appliance but that's quite a rare occurrence...how do you isolate the install?
But that isn’t what the GIUSP say. That is an isolated instance that you would dealYeh I get where your coming from I think. If you can't isolate supply appliance without isolating whole install affecting other appliances then you would can it at appliance but that's quite a rare occurrence...
Ok so a.r is isolate appliance and i.d is disconnect and cap...both with warning notice.
That’s what I think. But I am getting told otherwise on here.Ok so a.r is isolate appliance and i.d is disconnect and cap...both with warning notice.
Reply to Un-sleeved gas pipe, landlord saftey check. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
