M
micketherton
Many thanks for your informed opinionoh dear
Can you answer me this though. As every other response is also so full of wisdom, but the question is still not answered !
Is there enough water pressure, either within the combi pump system (or using mains pressure) to purge any possible future air build up in the upper floor loops, down the the ground floor maifold AAV. Or do I need to add additional air bleed points on the high points on each of the upper loops . (I'd rather not do this if possible, as it would be difficult aesethitically to put in place in the rooms).
As said mant times in my previous replies, I can easily retro fit a conventianal manifold system if my plan doesn't work out. But it would be very difficult to add air bleed valves to the upper floor loops under the T&G engineered oak floor if required!
So I need to know now if I will be able to get rid of any air in those upper loops by isolating at the manifolds and purging each loop with either the boiler heating water pressure, or even using a mains feed into the system?
Many thanks
Mick
